With thousands of people using PoolMath everyday, you can be confident the internal math is correct. There are lots of other variables that come into play but PoolMath is rock solid.
I wish there were an affordable pH test where the endpoint was as easy to judge as the FAS-DPD test
Something I have noticed and will remedy once the FC falls to 26 so I can go into pool safely--I have 3 PAL Treo PAL-2T2 lights (Electrician left me NO manuals, so I just called my installer to find out this info!) Ever since my problem last season, there has been kind of a brown liquid behind the outer lens covers. I am in contact with someone at PAL, who has told me how to remove the outer lens covers, so I will remove them and clean them as PAL recommended in 50/50 bleach and water. I still am waiting for PAL to get me a manual; I don't feel comfortable removing the lights from their niches to clean behind there without instructions on how to remove them.
I am assuming you have tried to download the manual off the internet for the light, etc. My interpretation of the "brown liquid" seems to me that it could be rust, but not sure. When you have a moment, please post up a full set of test results as well, considering you have the TF-100 Test Kit (We trust the results). You may want to hire a professional for one hour (probably no more than $75-$90) to come over and remove the light cover and skimmer cover to see if anything is lurking back there. For me, to spend the small amount of $$$ would be worth it. If someone wanted a lot more, then of course I would attack the problem myself. If you had any type of rust or galvanic corrosion, it would be very clear as rust or staining would start appearing on the screws around the light niche, the white trim pieces, in addition to some staining on the fiberglass. Once you rule out the "brown stuff" as rust, then you can easily clear your cloudy water. Again, please post up a full set of results
Just my 2 cents, last year I had similar issue, SWG wouldn't keep up, water looked dull, scrubbing and vacuuming didn't help. I searched online for manual for my light, found out 1 set screw at 12 oclock position was all that was holding it. Should be easy but working underwater trying to get leverage on a Phillips head screw wasn't easy. But once I got it out, the niche was very slimy, green stuff, turned rag and Mr Clean magic eraser green. Having put the light back in 'hand-tight' I can more easily remove it now, so I get a frequent water exchange this year.
Just my experience, I don't know anything about your brand of lights though.
You appear to have the same 3-3.5 inch LEDs as I do. I had to get a cover a while back which looked something like this: Fiberstars Clear Snap On Lens (pal-2000) (fpal-lc) - INYOPools.com. Unlike traditional lights (large 300W) that have a large cavity (niche) behind them that can hold algae, I doubt you'll have much issues with those. Although I did pull the covers off mine and clean them inside.
I agree. Nothing available for me either. My original LED covers did not have tabs either, but those covers still fit. Tight, but they fit. The good thing is that unlike traditional lights with a large niche, you shouldn't have an algae issue behind them. Just wipe the inside of the lenses perhaps.
I'm pretty sure that the only thing that matters for pool math is:.......No doubt the math is correct, but as you can see from reading this thread, there is some issue going on with my pool and PoolMath that we can't quite figure
Pool Volume
Strength/form of chlorine
Quantity used
There should be nothing special about your water as far as this is concerned.
Are all of your other results skewed as well, or just FC?
Dom
Okay, so I duplicated everything you did and it matched. Honestly, I'm not sure how to explain that over-shot. Since you were using a smaller size volume to be safe, you would think that your FC test after adding bleach might actually be "under" your goal as opposed to over. I agree that there's no way your pool is closer to 13K. I wonder if perhaps the bleach you got just happened to be a bit stronger? Normally it gets weaker, but you never know. There has to be an explanation, but I'm just not seeing it. Maybe I need more caffeine.
A couple other things I think you might want to consider next time though:
- Increase your pool volume to about 17500. 18K factory spec, reduce enough to compensate for mid-way up the skimmer (3-4" maybe), but I don't think that's 2K-worth of water is it? Your call though.
- Round-up your CYA to 70 and use an FC of 28 as your SLAM. We never split the vial measurements, it just gets messy.
If I see anything else that may apply I'll let you know. Good luck on your SLAM.
