- Mar 4, 2008
- 13
Does anyone have a source for a cheap, all in one ph Adjustment system? I need an ph down solution not a ph up soluiton. I like an all in one, buy this follow the include instructions, monitor and adjust as needed solution.
I have a Plaster Pool with a SWG and a water feature that runs constantly when the pump is on. I could probably eliminate my MA demand signifcantly if I turned off my water feature, but that is the wife's favorite Pool feature so that isn't happening either.
I know you can buy a pump, buy a jug, buy some hose and build your own, but I'm not that mechanically inclined. I can follow instruction like drill this, mount this, etc, but to do it all on my own, I'm just not that inventive with mechanical stuff.
I also have seen the do it yourself solution here in the forum. It is pretty well documented and I'm considering that solution.
I know there are couple of expensive (multiple thousands of dollar solutions) packaged ph lowering solutions, like the AutoPilot Total Control and others. None of those that I have seen are less then $2000.
What I want is a less then $500 solution like the Liquidator for PH control. Something that like the Liquidator can be installed by the average Joe Homeowner without having to do things like installting a CO2 tank and arranging for refills, etc. HASA who makes the Liquidator makes a "ph Adjuster", but I can't find a source and HASA has not responded to my inquiries via their contacts page.
Anyone have any suggestions?
Yes, I know this would not eliminate my need for PH testing any more then the SWG eliminates my need to test my CH. Yes it really isn't all that hard to dump MA in the pool once a week. I just like things to happen automatically if at all possilble.
