Just a matter of time before I needed to come and seek help
24hrs into SLAM and adding more chlorine to the required 24ppm FC. A second of not paying attention to my calculation I added too much chlorine and ended with 30ppm. Heavy Chlorine smell, bubbles on the surface just like carbonated water, at least some organic matter is being taken care of.
Should I let it slide back to 24 or do i need to keep it now at the 30 level from now on? I understand that one should not swim until FC is back at 24ppm.
Balance prior SLAM
FC 0
PH 7.4
CH 250
TA 120
CYA 60
FC for SLAM 24
Thank you
Hussain
Balance prior SLAM
FC 0
PH 7.4
CH 250
TA 120
CYA 60
FC for SLAM 24
Thank you
Hussain
