I have a Summer Waves quick set 10x30 above ground pool. My pool holds 1,074 gallons of water. It has a cartridge filter pump. When we bought the pool we brought a water sample to a pool supply store in town before adding any chemicals. Our water is high in iron (.81 ppm), so they sold us Metal Wizard by Haviland. She said 24 hours after adding the metal wizard to the pool we needed to add 2 pounds of stabilizer and one 1" chlorine tab to the filter. She said to replace the chlorine tab every time it dissolves. My pool sits inside my screened in patio. Doesn't get hardly any, if any at all, direct sunlight. The pool is green. I was told to buy bleach and pour in a quart or so, did that. Lightened the green, didn't fix it. Added 8 more ounces, nothing. We are just maintaining a lovely shade of green. We're cleaning the filter in the pump daily (it is orange every time we pull it out). I am vacuuming algae (assuming it's algae?) off the bottom of the pool daily. I'm ready to start over! Is that my best option at this point? We just want to use our pool! And quickly, if possible. Any tips on draining, and what I should do if I refill it? We bought a 3 way test kit at walmart, my chlorine levels are extremely high, so i thought we'd have killed the algae at this point. I have all of my initial test results from the supply store if that helps?
