Thread: High copper in pool 1 ppm
    Jun 2007
    Poughkeepsie, NY
    3
    Last year my husband used a copper based algeacide and we are still feeling the effects in our 16 X32 inground pool.
    Here is the data: pH 7.3, tot alk 132, total hardness 223, Cu 1, CYA 151, Free chlorine 0.3, total 1.5 . Our water is somewhat cloudy as I still can't see the bottom of the deep end. I have some 12% "bleach" I know I have to add, but wanted to get the Cu down before. Thinking of using HTH metal control.... ANy thoughts? Thanks!
    16x32 in ground pool
    Vinyl liner
    Hayward EC65 DE filter
    I've used metal sequesterants in the past, worked fine. Something else you may consider is the new clorox with rust out, or whatever it's called.
    I used this in the past, not for metal but because I bought it and didn't know any better, and found it would leave small brownish deposits about 12' from my return, just like the sequesterants did. There was some discussion about this type of clorox at poolsolutions, and I think others reported similar experiences.
    Not something you'd want to use every day, but possibly until you don't have any fall out?
    Jun 2007
    Poughkeepsie, NY
    3
    Oh, never heard about that type of chlorox. I only see the scented stuff & chlorine free type on the Chlorox website. I would think that to remove rust, some type of oxalic acid would be needed. I ended up putting in 1 pt of "stain away " and Cu is now zero, if I can believe that result... will have a recheck done at the pool store.
    I have been checking various manufactures pool products using their respective MSDS sheets as chemical composition is listed... that way I can compare the products for like chemicals. Pool magnet, stain away and metal control all contain Hydroxyethylidene Diphosphonic acid. Do you or does anyone know of standard chemical procedures, like ASTM methods or protocals for pools that I could reference & do my own testing... making up reagents and such? Thanks!
    Vinyl liner
    Guest
    Quote Originally Posted by harmug
    Both LaMotte and Jack's Magic have a seqesterant test kit available tht will test the level of HEDP in the water. The LaMotte kit is 4064
    I am using the hth Brand Metal Control for Iron, a double dose, and it is working fine, but I have no idea about for copper.
    Your CYA level is pretty high, here is a pretty good thread about that, it gives charts and explains what your FC levels should be with such a CYA level for save water. http://www.troublefreepool.com/viewtopic.php?t=1225
    16x48 Metal Frame Intex
    6000 Gallons
    2000GPH Intex Pump
    Fort Wayne IG Vinyl 18 x 36 (22,000 G)
    3/4 hp Pentair Pump
    Sand Filter
    Polaris 280 w/ booster pump
    No heater yet...solar cover
    Mount Airy, NC
