Finally got my inground pool up and running and have noticed two leaks. From the clear elbow I have leaks at both ends. Where the top of my Super Pump sp2607x10 basket connects with the sp710xr50 Vari-Flow valve it's leaking and where the clear elbow is connected to the top of the basket is leaking also. I found the part I need for the connection to the Vari-Flow sp1480 here https://www.amazon.com/Hayward-SP1480BLK-Self-Aligning-Replacement-Cartridge/dp/B004VTGIF2/ref=sr_1_3?ie=UTF8&qid=1466357580&sr=8-3&keywords=hayward+sp1485e. I cannot, however, find the bottom white piece that connects to the basket. The top circular hand tightening part is labeled sp1485-e, but there is no label on the bottom part in the shape of a nut that screws into the basket. I'm also unsure if there are o-rings involved. Here is a picture: Thank you.
