Hi Jezza, the pool is completely clear. You can see everything in both deep and shallow end. It is great. I only need to adjust a bit my numbers.
This morning I took the first complete reading after the deep cleaning of the filter. Here are the numbers:
FC: 4
CC: 0
TA: 150
PH: 7.6
CYA: >20
I did not read the calcium hardness, which was 160 on the 18th of June. Now, I used the pool math and it asked me to add 6lbs 11oz of stabilizer to get my number to 40, which is my goal. It is a lot to put in a sock and leave it there. Is there a liquid form that i can use for at least part of the required amount?
Should I worry, or adjust the TA?
Had a load of bathers yesterday, so I am going to add about 1/2 gallon of chlorine for the day.
Thank you so much everyone for sticking with me and guiding me to find the solution for my pool.
FC: 4
CC: 0
TA: 150
PH: 7.6
CYA: >20
