Need help just started BBB method
Okay. You did input everything correctly. Good job!!!
If your TA is truly 100, add the MA now. Note the time. Get back to me on the % strength of your bleach. A half hour after adding the MA, you are going to add bleach, so you have time to check the %.
Added 63oz bleach 6%
Added 3.0oz MA
Only added 16oz CYA
(Did this to see how well it reacts)
Pool math said 30 oz I wen just over half that
Here is my pool math info from my readings
Pump is running now how long before I should test it again?
No worries. Also, keep your MA and chlorine in separate places in your garage or wherever.
Nice pool!!! Got leaves? Hahaha! We need to see that water sparkle!!!
Retest pH, FC, and CC after a half hour or so. Still got that pump running 24/7?
