Your FC is high for not having any stabilizer recorded yet. In fact, because your FC is high (over 10), and your pH is showing low (usually it goes up when FC is elevated), I would recommend allowing your FC to drop just under 10 then re-test your pH to make sure 7.2 is a true/accurate reading. Once you validate the pH at 7.2, then increase FC to "12" (assuming your CYA goes to 30). If your CYA goes higher than 30, then your FC may need to go higher as well.
We really need a CH reading. That's important to analyze your plaster and "CSI" level. You should be able to get some CH reagent locally. If not, I would request a refill from TFTestKits.com as soon as possible. By looking at your thread here, we want to know if we can rule-out a plaster problem as opposed to simply treating an algae problem.
For photos, have you tried linking your photos from Photobucket? That's what many of us do here on TFP. Upload your pics to Photobucket (free), then copy & paste the IMG code for that pic from Photobucket to your TFP post. Works great.
