Results 1 to 7 of 7
Thread: does polyquat 60 raise pH?
    Aug 2008
    Las Vegas, NV
    116
    I have been doing everything just as I always have. My pH has been pretty consistent. There was a big rain last night and today. I drained some out and checked the chemicals. My CL as still at 11, but my pH was over 8. I added the drops for the acid demand test and just don't think something is right. I added about 2-3 drops at a time and then mixed. The color changed to purple and then as I got to 35 drops, the color changed to yellow (low pH). There was never the pinkish orange (or however you would describe the color of 7.6)
    Before I did anything, I wanted to ask opinions. I added the polyquat about an hour before i did the test.
    Pam
    Re: does polyquat 60 raise pH?
    Polyquat will not have a significant effect on the PH, though it might raise it just a little.
    If you post a full set of water test results we might be able to figure out what is happening.
    Aug 2008
    Las Vegas, NV
    116
    Here's my numbers
    Cl 11 (same as it was this morning--it was overcast all day)
    cc 0
    pH 8 (could be higher)
    TA 110
    CYA 90
    CH 110
    Pam
    Hum, nothing there stands out.
    Rain can raise the PH, though not usually dramatically. If it was a major storm then it was probably the rain.
    Aug 2008
    Las Vegas, NV
    116
    ok then, I'll just get out the MA and low it a little. I think start with about 12 oz. and then check it again.
    Should I lower the pH to 7.4 or 7.6?
    Pam
    I would aim for a PH of 7.4 or 7.5.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Go with the 7.4 to give you some cusion while you are gone, then if it raises a bit while you're away you should still be okay.
