Drained and powerwashed my pool yesterday.
Filled my pool last night.
Turned my pump on this morning. Let it run an hour before doing water test.
Taylor 2006 kit and an Aquacheck phosphate test kit.
Before drain numbers
FC 0
pH 7.4
TA 140
CH 750
CYA 220
Phos > 1000
After Drain and Fill
FC 1
pH 7.9
TA 140
CH 250
CYA 0
Phos <200
Where do I go from here?
We drained the pool as lower as it could go without damaging the pump.
I know I need to add CYA I don't have a problem buying liquid to get it up fast enough to hold Chlorine. Is there any difference of brand?
We are giving up on tabs and switching to BBB method.
We have Calcium build up on tile and would like to lower the ph to 7.2 to help with that.
We took a class on swimming pool construction many years ago and was told not put more than 2 cups of Muriatic Acid a day.
We had this pool built 12 years ago.
Thoughts? Order of operation and adding chemicals into the pool?
Paul
FC 0
pH 7.4
TA 140
CH 750
CYA 220
Phos > 1000
FC 1
pH 7.9
TA 140
CH 250
CYA 0
Phos <200
Paul
