Hey all. Ok, last fall our old liner bit the dust, and slowly leaked out some water before winter freeze. Then in the spring, the rest leaked out...all 25,000 gallons. (it's a 33 foot diameter pool).
Anyway, I have purchased a new (overlap) liner for it. I notice that where the water leaks were it washed away alot of the sand coping..and then 3 of the vertical columns sunk about 2 inches......So I need to raise those columns back up so they are level with the rest of the pool What is the best way to do that? Can I use a string level from across the pool to bring the low side back up to level? I want to be careful raising the vertical columns, so I don't knock the wall out of the lower retaining ring, etc etc.
Any help would be great!!
Dan
Dan
