I also noticed that you were targeting 30 ppm from 20 ppm in your Pool Math. Unless you're planning on using pucks later in the summer or off and on throughout the summer, I'd suggest going to at least 40 ppm CYA if not 50-60. You'll consume less chlorine that way based on your location. But you might just be working your way up to that slowly.
