Instead of running a GFCI breaker from the panel for the convenience outlet can I substitute that one for a GFCI outlet and save a few bucks or is it better just to use the GFCI Breaker? This is only for the convenience outlet not the pump...
I am no expert by any means, but I understand electrical enough to run it myself. My opinion is that, not sure on how close to the pool you will be putting this outlet, but it really isn't different than any other outdoor receptacle. NEC code states:
[h=3]Article 210.8(A)(3)[/h] All 15- and 20-amp, 120-volt receptacles must be GFCI protected. This may be with a GFCI recptacle or a GFCI breaker.
and
[h=3]Article 406.(8)(B)(1)[/h] Outdoor receptacles located in wet locations that are unprotected from rainfall, must have a cover that is weatherproof to protect the receptacle when a cord is plugged into it and when not in use.
I just used GFCI outlet with a heavy duty metal in-use cover myself for my convenience outlet. I can't seem to find anything in NEC specifically stating within x' of a pool, the circuit must be GFCI. Again, just my experiences and I am by no means a licensed contractor.
