I'm going to be pouring about 20 ounces of MA in my pool later today in front of return jet to lower my pH, but do I really need to pour the 20 ounces over 2 FULL minutes? That sems like an awfully long time to sit there and pour 20 ounces?
It is your pool and you will come up with your own routine. But that is certainly a safe recommendation.
Good advice, I'll pour a little and see how fast it sinks and adjust from there. I don't mind pouring slowly, just didn't want to if I didn't have to. Will it really mess up the plaster on the bottom of the pool even if its a small amount like 20 ounces?The faster you pour acid, more of the acid will sink to the bottom of the pool. With a slow pour over a return, more of the acid gets distributed through the water column. Watch to see how fast the acid is sinking when you add it and adjust as necessary.
It's always best to brush the pool to help distribute the acid and prevent any damage that can happen if the acid sunk to the bottom of the pool.
I typically pour on 20oz or so and it takes me less than 30sec in front of the deep end return. I then give the pool a brush (~10mins). That's more than sufficient to dilute and mix the acid.
2 full minutes is overkill.
