TB, my work computer won't let me go to your photo. But I'll say this going into it blind from here ..... if your water is cloudy, that's probably organic material that still needs to be eliminated. I would be prepared to do a SLAM. If you wanted more confirmation, you could do an overnight test as instructed
HERE, but I suspect a SLAM will be needed. Good thing is your water is not a swamp, and you've done a lot of great work already. Plus, your current levels are in perfect shape to simply start the SLAM. Treat your pool as a CYA of 30 and keep the FC at 12 and maintain that 12 FC until you pass ALL 3 SLAM criteria. The SLAM link is below in my sig if you need it. A SLAM will clear your cloudy water if you follow those instructions. Let us know if you have any questions.
