Is that "normal" on the 3-way valve? When I first tried to get the pump running I didn't have the 2nd cutoff valve installed yet. It was just the 3-way. I had the handle in the vertical direction s that it looked like it would run through and no water came out of the solar line. I slowly turned the handle to blow some water through it and clear debris. I'm going to rotate the secondary cutoff to make sure water comes out.
Maybe I'm misunderstanding a 3-way. Maybe it's not to divert water here and there, but rather an all off or all on type of valve? Is that really what it does?
