The in-ground pool has plumbing for a water feature but the former owner took it with them...
I was thinking of using PaveStone Rumble Stone to build a structure (maybe 36 in w by 18 in deep by 24 in high) and then building a scupper out of acrylic to sit inside and create a sheet water fall coming out at about 18 in high. The wide of the water fall would be about 22 in.
We have a PaveStone Rumble Stone fit pit on the deck so the 2 structures would hopefully compliment each other.
I was looking on line at waterfall mainfolds and they look like plastic or metal box with a protruding thin lip opening. I thought I could cut and cement the pieces from a sheet of acrylic to make the box then use PVC pipe to connect to the existing plumbing.
Right now it doesn't cost anything to dream but have to ask if you think I am being too adventurous or if you know of a better way.
Many Thanks, Dave
Many Thanks, Dave
