Assuming the correct ratios of FC and CYA in a SWG pool, what are the pros and cons of having high FC vs low FC?
I try to maintain FC:6 CYA:80. Why would 4:60 not be recommended?
Also why do "Most saltwater chlorine generator (SWG) pools appear to prevent algae at a lower minimum FC level compared with the minimum FC column for manually dosed pools."?
Surely Cl is Cl regardless of how it is regulated in the pool? Is this just based on owner experiences?
Cheers
Squib
Cheers
Squib
