Pentair EasyTouch 4P vs PL4
jmastron
509
Sacramento, CA
I’ve been looking into an EasyTouch system, focusing on the 4P, but just noticed that Pentair has another newish EasyTouch line -- the PL4 (and PS4 for pool+spa):
http://www.pentairpool.com/products/automation-easytouch-control-systems-49.htm
http://www.pentairpool.com/products/automation-easytouch-pl4-and-psl4-pool-and-spa-control-systems-473.htm
From what I can see, the main difference is the PL4 doesn’t have a built-in load center/breaker slots or the optional built-in IntelliChlor power supply; it does have a bundle that includes the ScreenLogic wireless interface that can be purchased separately for the 4P.
From a quick search on pricing, these seem to be equivalent in cost and functionality:
4PSC-IC40 (520593) + ScreenLogic wireless (522104) = ~$1500
PL4 (522353) + IC40 cell (520555) + IC power supply(520556) = ~$1500
The cost advantage comes if I decide to go with a Stenner pump now but later end up installing an SWCG.
The only disadvantage I can see to the PL4 setup is having 3 boxes on the wall (EasyTouch, load center, SWCG supply) instead of 1, with the resulting conduit between them. Any other differences that I’m missing? Do they otherwise have the same control capabilities?
I know nothing about the PL products, but I did take a quick look at their brochure and they look like they have way less capabilities than the Standard EasyTouch.
As an example.. The EasyTouch can control 2 Intelliflo pumps, the PL series 1 pump. The EasyTouch can have 12 schedules, with the PL only 4. The EasyTouch has 8 feature circuits while the PL has 2. The PL seems to have only 4 speeds.. I'm not sure how many speeds the EasyTouch has, but I have yet to run out.
I only skimmed the brochure, but at this point I can't see anyone that would benefit buying the PL instead of the standard EasyTouch. You can buy an EasyTouch 8 with an IC60 plus valves for $1,800 from Sunplay.
Jim R.
EasyTouch PL4/PSL4 Control Systems Model Part Numbers
522352 PL4 - Single Body / Base System (no Indoor Control Panel, no actuators)
522353 PL4 - Single Body / ScreenLogic® Bundle (no Indoor Control Panel, no actuators)
522354 PSL4 - Pool/Spa / Base System (no Indoor Control Panel, two actuators)
522355 PSL4 - Pool/Spa / ScreenLogic® Bundle (no Indoor Control Panel, two actuators)
EasyTouch Control System Model Part Numbers
EASYTOUCH CONTROL SYSTEMS WITHOUT INTELLICHLOR TRANSFORMER BUILT-IN
520591 EasyTouch 4P - Single Body (base system - no ICP, no actuators)
520703 EasyTouch 8P - Single Body (base system - no ICP, no actuators)
520538 EasyTouch 4 - Pool/Spa (base system - no ICP, 2 actuators)
520540 EasyTouch 8 - Pool/Spa (base system - no ICP, 2 actuators)
EASYTOUCH CONTROL SYSTEMS WITH INTELLICHLOR TRANSFORMER AND INTELLICHLOR CELL
520592 EasyTouch 4PSC-IC20 - Single Body (includes SCG integration & IC20 cell)
520593 EasyTouch 4PSC-IC40 - Single Body (includes SCG integration & IC40 cell)
520704 EasyTouch 8PSC-IC20 - Single Body (includes SCG integration & IC20 cell)
520705 EasyTouch 8PSC-IC40 - Single Body (includes SCG integration & IC40 cell)
520542 EasyTouch 4SC-IC20 - Pool/Spa (includes SCG integration & IC20 cell, 2 actuators)
520543 EasyTouch 4SC-IC40 - Pool/Spa (includes SCG integration & IC40 cell, 2 actuators)
520544 EasyTouch 8SC-IC20 - Pool/Spa (includes SCG integration & IC20 cell, 2 actuators)
520545 EasyTouch 8SC-IC40 - Pool/Spa (includes SCG integration & IC40 cell, 2 actuators)
521150 EasyTouch 8SC-IC60 - Pool/Spa (includes SCG integration & IC60 cell, 2 actuators)
CANADIAN EASYTOUCH SYSTEMS
520914 EasyTouch 4P-C - Single Body (salt ready system, cell must be ordered separately)
520915 EasyTouch 8-C - Pool/Spa (salt ready system, cell must be ordered separately)
520911 ntelliChlor SCG IC20 cell for Canada
520912 IntelliChlor SCG IC40 cell for Canada
