Suzanne, your regular chlorine reserve should be sufficient to take care of anything Mickey may have done to your water, but if you want to add a couple cups of bleach to the skimmer (I'd do it before pulling out the basket and performing the funeral ) it's not a bad idea.
'Shocking' is when you elevate the amount of free chlorine in the pool to the point it will kill whatever bio-nasty or algae is in the water - how much you need to add is dependent on the CYA level. This is a real quick answer, if you have any follow- up questions -- all you need do is ask 8)
