amjohn posted here an impressive DIY project of a solar heating system with all the necessary controls and other bells and whistles. Does an “everything included†kit exist, which contains all the controls, ground mounting frames etc.?
My pool’s surface area is about 550 Sq feet. Will two panels of 20x4 each be good enough? This is 29% of pool surface area. (see sig. for more pool details.) The panels will be mounted on ground frames facing South. If the entire kit from soup to nuts is not available, where can I get the other components? Unlike amjohn, I can’t spend too much time on the design and installation. If you installed a similar solar system please post.
