Help! Our inground vinyl pool with white steps and white aluminum bullnose coping is showing it's age (20 years) and is in need of a remodel. Hope to achieve a more "natural" and high-end look. I'd like to replace steps with gray or better yet, vinyl over steps and get rid (or cover up) aluminum coping. Have had 3 or 4 pool companies out to look at it and all I hear is "you don't want to do that..." , "too much trouble and too expensive to tear out steps", "shouldn't remove coping... asking for trouble." So, I'm looking for options. All the "remodel coping" pavers I see that would cover up the existing aluminum coping are made for a straight-edged existing coping. Can I use those remodel coping pavers, cemented in, over the rounded bullnose without an issue? Also, the very top edge of our steps extends above the surrounding deck (it's not the level, cantilevered steps). Does anyone know of ideas to cover that top edge with paver coping? I'd at least like to have paver coping around the entire pool if I cannot replace the steps. Lastly, the liner is slipping out of the track in spots. Considering the age of the pool, will a new liner likely fix that or could I have a track failure? And if the track is failing, wouldn't I need to cut up concrete to install new liner track? Just cannot find anyone with solutions... too many "it can't be done"s. Thank you for any and all help and/or suggestions. Blessings.
