Thread: priming the pump
    coastal's Avatar
    Apr 2009
    Naples Florida
    87
    priming the pump
    I've done a search but couldn't find th answer to this question, sorry if I missed it.
    What is the best way to prime the filter after I've taken out the cartridge for cleaning? I have used a hose but that just seems to send the water back in the pool and not fill up the filter area.
    Aprox 30' X 18' Free Form Shot - Crete In Ground
    Pool, Spa, Sunshelf, 8800 Gallons
    Pentair Intelliflo Vairable Speed Pump
    Pentair 150 Sq Ft Cartridge Filter
    Pentair Ultra Temp Heater
    Apr 2009
    Sarasota Florida
    143
    Re: priming the pump
    If all is plumbed properly all you should have to do is close it all back up and turn the pump back on. It should fill the filter canister up on its own. If your pump lost its prime then that is a different story.
    Mike
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    Mostly you just turn the pump on. Once the pump us running, you should open the vent on top of the filter and let all the air out. When water starts running out, you close the vent again.
    coastal's Avatar
    Apr 2009
    Naples Florida
    87
    It does fill again once I close it up but I was worried about running it with all that air in the tank. I guess I could close off the returns to keep it from draining out. That is if I can turn those valves, they have been in the same position for 3 years.
    Apr 2009
    Sarasota Florida
    143
    There is a bleed at the top of filter tank, turn pump on, open bleed until water comes out. Close bleed and carry on.
    coastal's Avatar
    Apr 2009
    Naples Florida
    87
    AH HA!
