Hello all,
Just conducted a home test of my pool water and discovered the following
TC 2
PH 7.8
TA 160
I used the pool calculator, however, do I enter the values to lower PH or the values to lower the TA. If you shoot for 7.2 PH, I get one value for miratic, if I had the desired TA based on my current reading, the miratic value increases significantly. So which value do I aim for, one or the other or both?
TC 2
PH 7.8
TA 160
