Keep adding more dichlor till the FC holds? I've been testing the CYA and it comes to about 33, but maybe that's not enough to hold it good?
No, keep adding more bleach until the FC level holds between 3 and 5ppm. CYA at 25-35 is fine, leave it there. It is important not to let FC drop to 0 before you add more bleach. So, either add enough so that it will be 3-5 the next time you get in and/or test or test and add a smaller amount a few times. I wasn't adding enough bleach to kill everything and retain a residual FC level the next time I got in the tub or tested and added more. Test about 15 minutes after you add bleach and see where it is. Mine would drop quickly at first. If it stays around 5 then test again in an hour to see if it is still holding.
Keep some notes on how much you add and what the residual level is and you will figure out what the normal chlorine demand is.
200ml of bleach is very close to our long term daily average (9 months) of bleach additions in our tub. Others suggest that this is more than what they need, but that's what we need to add in order to keep free chlorine in the tub as indicated by testing.
I've also found through testing that cya disappears at a faster rate than expected as well. Something like 4-6ppm per week.
I suggest that you go ahead and add what chlorine you need to, in order to keep your FC and CYA numbers in the appropriate range as indicated by your testing. That's what we do.
Just as an example, two nights ago we had some people over for a party, so there was 5 people in the tub for quite a few hours. Over the past 24 hours, I've added 2 cups (480ml) of bleach (8.25), plus a tablespoon of the granulated stabilized chlorine powder (another 12ppm fc/11ppm cya) to keep up with the additional chlorine demand, and to replace cya from all the splash out. I'll still need to test tomorrow to see if FC is holding like normal.
The tub makers and retailers set us up for failure in my opinion by telling us to not use liquid chlorine for sanitation. At the rate of chlorine addition that we do, cya would build something like 100ppm per week. That is not sustainable without problems with bacteria growth coming up in short order. They essentially put their profit motivations to sell chlorine powder ahead of their customers health. Hot tub rash is no fun, and Legionnaire’s disease isn't something I care to deal with. People die from it. (google it).
CYA is lost through splash-out (drag-out is probably a better term for hot tubs) and it does get oxidized (slowly) by chlorine. The loss of rate of CYA from chlorine oxidation in a pool is roughly 0.2ppm/day or a few ppm per month. In a hot tub, the loss rate due to chlorine oxidation is higher because the temperature is higher most of the time and the loss rate can be as high as 5ppm/month or more (it also depends on how high you let the FC get after dosing with chlorine). So it is not unusual at all to see some loss of CYA in a well used hot tub.
If your interested in the chemistry of CYA degradation, see this post - Degradation of Cyanuric Acid (CYA)
Wow that's 6 ppm a month. So I should really be testing CYA once a month or just the first month after and then add dichlor to top it up...once I know how much it depletes I don't have to test any more. Thanks for the info!
I have started having the same problem with the red rash. It's mainly on my calves, back and sides of my arms. It drives me crazy!!!! I bought my hot tub in April of 2015 and kept my temp. about 94 degrees during the summer. Then winter came and i raised my temp. to about 98.That was in October. That's when i started having trouble. I use bromine in my tub because that's what the pool store set me up with. Was wondering if anyone thinks i should switch to chlorine? I am very new to this.
Thanks
I changed my water in November of 2015. I use a flaoting dispencer with 1 inch bromine tablets in it. I also use bromine concentrated granular once a week as a shock. I use test strips but i now know they are not good. I have already ordered a test kit.
Thanks. Yes 7 months was to long. But we were in a very bad drought here in Texas. All is better now with our water situation so I will change more often. Thanks for a answering my question. I do think I will switch to chlorine.
My wife and I use our hot tub every night for 15-20 minutes and at times have both suffered the itchy skin, occasionally with small red bumps. I too looked long and hard for solutions, but I think in our case it is more attributable to dry skin (especially in the winter months) than it is to water chemistry. Our spa died several weeks ago, and during the time we have not had it running, I have still had some itchy patches in the same places I have gotten them when using the spa.
This thread has all the information you'll need for converting to chlorine - How do I use Chlorine in my Spa (or pool)?)
I recommend when you are ready to empty the hot tub that you get the Ahh-some product and deep clean the hot tub before converting. You can use the old, brominated water in the tub, flush the system with Ahh-some and then refill the hot tub with fresh water and start using chlorine. Follow all of the instructions for the Ahh-some product carefully and do not over-dose it; it is VERY powerful.
Good luck and ask questions (start a new thread though) if you need help.
