Hello,
I closed my pool on Sept 12 after dye tests were done and any leaks found were plugged. The pool is covered and I have been checking the level to be sure
I lost 1/4 inch in 5 days in the pool and it is getting cold here in Michigan. What should I do?
Will it possible for a leak detetction service to fix any leaks in winter
Concerned as I do not want the water to drain out completely!
Very concerned!
Thanks
Very concerned!
Thanks
