I'm new but my pool is running great:
1.6x5x5 m (40,000 litter)
Jandi Apure 1400 chlorinator (560gram Cl/24 hrs, or about 0.7 FC in one hour)
Salt 3500
TA 90
Ph 7.6
CYA zero
FC 0.7 at midday (100% Chlorination running)
water is sparkling
Having read thru the pool school and details info on Cl/Cya, I'm concluding that my pool is small enough
and my SWG big enough, that I can use this cycle:
1. Run pump for 1 hour at day break, bring FC to 0.7
2. Idle 3 hours, letting FC get destroyed by UV, down to 0.011 minimum safe level (half life 30 minutes)
3. repeat until sundown
4. run pump continuously when pool is being used
Advantages:
1. lower overall FC
2. minimum HOCl at all times (never too low due to CYA eat up all HOCl)
3. very high HOCl (compared to using CYA) at night, ensuring no contaminations/algea can survice
Since this isn't mentioned anywhere, what am I missing?
Salt 3500
TA 90
Ph 7.6
CYA zero
water is sparkling
Advantages:
1. lower overall FC
