- Jun 22, 2014
- 47,946
- Fiberglass
- CircuPool RJ-45 Plus
Okay, got it. Then the only other piece of advice I'd pass along to you is the amount of bleach. Since your FC was 1.5, and your SLAM level FC is 24, the calculator shows a requirement for 4 gallons and 1 quart (8.25% bleach) to get that high. If your pool guy only added 1 gallon, you're not at SLAM/shock level, you're only at about 6.5-7 ppm. Even 10% strength might only get close to 8ppm. Just wanted to pass that along. You can always add more.
