Question about blowing out equipment after lines are done
run53
410
I am closing the pool this afternoon and couldn't remember the order in which I should remove the equipment plugs (if it matters) once all the returns and supplies have been plugged.
For example, Should I relieve pressure/drain the filter first, then remove the Polaris plugs, then the heater plugs? I assume the pump plugs are last to be taken out as that is where I blow from.
