On Labor Day weekend I had a breakout of MA. I did a SLAM on 9/14/15. During the SLAM I am guessing that I probably over did it and had the FC at least up to 50+. I know that I have should have not have put that Chlorine in the pool. I ordered a t-100 test kit, but got results from a pool place today 9/17/15. I haven't added any chlorine since doing the SLAM on 9/14. Water temp is 74 degrees. I use a well to fill the pool. I don't have a the solar cover on the pool. What do I need to do in order to get the pool ready to close? The pool water is sparkling blue and is totally clear. No damage appears to have been done to the liner since the SLAM. The liner is still has dark blue as the day it was installed. no water is leaking from the pool and I only have to add water due to night time evaporation. The night time temps here get into the 40's and I can see steam coming off the water at night. The pool gets full sun. I have pulled the steps from the pool and no one has swam in the pool since 9/14.
FC = 20
TC = 20
CC = 0
PH = 7.4
TA = 107
CH = 103
CYA = 47
Copper = 0.1
Iron = 0.2
Manganese = 0
Nitrates = 0
Total Dissolved Solids = 0
Phosphates = 0
Saturation Index = -0.2
Endure = 9
thanks
FC = 20
TC = 20
CC = 0
PH = 7.4
TA = 107
CH = 103
CYA = 47
Copper = 0.1
Iron = 0.2
Manganese = 0
Nitrates = 0
Phosphates = 0
Endure = 9
thanks
