My IC 40 is reading "Low Salt". My test strips show that my salt level is fine. Based on the amount of salt I've added I think my salt level is good. I've take the IC 40 off and no scale buildup is visible. Pentair says to do the acid wash anyway and to have the water professionally tested at a pool store as the strips tend not to be accurate.
Does anyone know if there is a history of this with the IC 40s and if so what should I do?
Also, will the cell operate even with a "Low Salt" reading, i.e., will chlorine be generated as long as the salt level is correct even if the cell thinks it is low?
Thank you.
Thank you.
