- May 27, 2013
- 43
- Plaster
- Jandy Aquapure 700
Hey folks!
Please note the 2 photos below. I assume this a flow sensor. As you can see from the second pic, water spews from it when the pump is on.
I opened it. It still has a small rubber o-ring and I tightened the clamp. But it still leaks. I think this is a part of a leak issue I've been dealing with all summer.
Is there an epoxy or sealant I should use on it? Do I need to replace it?
Thanks!
Thanks!
