Good morning! Yes, this is fine. Fire-away with your question so members can try to help. But perhaps in the future consider giving your new post a title related to what you are asking. That might help receive better attention and avoid confusion.
The only thing I would suggest about your test results in to add a little acid per the calculator to reduce pH. You always want pH in the mid-7s. 7.2-7.8 is acceptable. Also, I don't recall how long it has been since you added stabilizer for your CYA. If it has been more than a week since you added stabilizer, you should increase CYA to a higher number here in TX with our hot sun. At least go up to 40 to help protect your chlorine (FC). Not sure what "The" was supposed to be? Calcium Hardness (CH)? If so, there's no need to worry about that one right now.
