Hi Alex.
That's great, I'm so glad things are under control. You've done a great job.
It is apparent the CYA is still hurting you by today's FC drop, but it will, hopefully, catch up soon and give you some FC holding power in there.
As long as you continue to Maintain your FC at the appropriate level, or slightly above for your current CYA, at all times, you should be just fine.
Of course, while you're waiting for the CYA to catch up, also continue to Target an even slightly higher FC to compensate for the drastic drops when no one is going to be in the pool to prevent the FC from ever dropping below the minimum because that's when algae can, and almost always does, begin to become an issue again.
Have a wonderful night, and Enjoy.
