Hello, I hope you can see my profile... let me know if not. Thanks for the help in the past, those issues resolved.
Replaced water in late May or early June due to calcium levels out of this world! Using Taylor 2006 teat kit to report readings. The issue; I am burning through Muriatic Acid by the quart/gallon weekly to hold the PH down.
FC = 3.8 (turned down generator a bit as I increased the Cyanuric Acid, SWG running about 50%)
TA = 110
PH = 7.7 (had lowered the day before to be in ~7.4 range, note it took a LOT to get to the 7.4 range, PH can spike quickly... off chart!)
CH = 260 (New water...)
CYA = 45/47 (added stabilizer to push to TFP recommendation 60/70, the 45/47 was established slowly, over a month)
Temp = ~90
Any ideas what may be causing the high levels of MA to be required?
TA = 110
Temp = ~90
