In my jacuzzi saniclear 20 instruction, it says the adjustment is the % of time the unit will run.
If the unit is set to 40% when the pump run 24 hours a day, does it mean that if I set it at 60% and the pump run 16 hours a day, it will have the same result?
Also it won't impact the cell life since I'm running it for the same amount of time per day?
Am I correct?
Thank you
Am I correct?
Thank you
