Received a used 18x48 Easy Set pool. Read till I couldn't read anymore. Cleaned with diluted bleach cleaner and Nylon outdoor broom, leveled, sanded, tapped, sanded, tapped, sanded and tapped some more, added foam board, tarp, then pool. Thinking I'm good to go. Blew up the top ring and all the air went out in less than 10 minutes . Used soap & water, bubbles, brush. Finally found the main culprit a 3/4 tear about a foot from a valve opening. Searched her inch by inch and patched anything resembling a pinhole or soon to be tear.
It's been about 5 hours since patching. Can I fill the ring at this point and try again?
Thank you,
Sharon
Intex Easy Set 5500 Gal
Intex Krystal Clear Saline System CS8110
Intex Krystal Clear Filter Pump 1500 GPH
Intex Deluxe Surface Skimmer
Thank you,
Sharon
