Is there any advantage or problem running the pump every now and then, months before opening the pool?
The last 2 years I have taken the solid cover off my pool in late April (Rhode Island), and the water has been almost perfectly clear all the way to the bottom (IG 18X38 8.5’ deep). This year I took a peak, the water is cloudy and I can’t see the bottom.
If I run the pump now a couple of times a week with the cover on, will the water be clear when I’m ready to open the pool, or should I just wait till April.?
I have had the pool for 2 years using BBB and only saw slight cloudiness once, which went away in 2 days by running pump 24 hours.
If it’s cloudy and green now will it be way worse in April?
If I clear it up now will it stay clear till April by running pump once or more a week and adding chlorine, with the cover on?
Thanks for any advice.
