Hello, I have read extensively on this site and elsewhere as to how to look after a hot tub, however, I have some remaining questions. I will be using the hot tub on a daily basis and it is a used beachcomber 2 years old that came with my house purchase. Because I will be using it mostly daily I can't work out which is the best method for me. I was leaning toward a bromine system initially, but have now read cholrine might be better for somebody who will use it as often as me, is that true?
Questions below, and thank you in advance for any input. Kind regards, Dean
If using at minimum every 2 days but most likely every day would you suggest a 2-step bromine only and not 3? But maybe I have read that for more frequent use chlorine is easier, is that correct?
If you think 2 is the way ahead in my case, how often would I be oxidising after use? presumably this will be dependant on my bromine level etc?
For that high a use would you recommend an ozonator and if so what are the disadvantages or possible concerns of using one
Am keen to use the Borax, is this sensible in a 2 step system, is it sensible in a 2 step system with an ozonator?
Whats the best product for cleaning the filter with this sort of system and how often should i do it?
I plan on using ahh-some prior to draining the used hot tub. What should I use to clean it, just bleach and water?
