holy hercules is that one big pool. I can drive both my vehicles in there and still have room for a good swim. Sweet looking concrete work around the sides too!
approx 42K sloping from 3' to 6' at the deepest.How many gallons is it?
I used steel to form the inside curve of the corners. It was temporarily bolted to the wall, concrete was poured behind the curved piece of steel and, then when the concrete was set, the steel form was removed. You can see the finished curve about the 10th picture down in the first postHow did you attach the steel? Also did you pour concrete behind the void between the steel and wall?
I replaced the liner (defective) in this pool after 1.5 years in service. The concrete walls were wet in a couple of places making me think it does not form a perfect seal all the way around.I use that track all the time and I sometimes wondered what happens when the water level goes above the track. Does it slowly seep out?
Good question and I am sorry I did not see it sooner. From the beginning, the pool was designed to hold water successfully with no back fill whatsoever on any of the sides.. If I remember, that was about 1100' of 1/2 rebar horizontally and 600 laterally. I know that was w-a-a-ay overkill but I certainly didn't want any cracks.Just curious how is the other wall holding up so much water? It looks like it is not backfilled. Did you have to reinforce it in any way? Would be great to see a picture from that side of the pool to get some ideas on how you decorated it.
