Pogueld
0
Run53 - Earlier you said "I would think I should be able to drop to an FC of 3-5 as that is what PoolMath suggests for CYA=70 and SWG." Although that is true, I think in your case you might want to target a little higher. I have read a number of folks targeting in the 7-8 range, just so they don't run into trouble. As long as you are under, let's say 15, you are fine. Really, as long as you aren't over 28, you are okay. I just wanted to give some extra margin to work with...
This is true. I have a CYA of 80. I target 8 so I can be closer to 6 than 4 in my 4-6 range. It's more assurance that I will never get below 4.
[emoji176] Lisa P.
