- Jul 17, 2015
- 19
- Plaster
- CircuPool Core-55
Having some work done which required emptying the entire pool. I'll be refilling in the next couple days. During the transition, I'm also moving over to SWG with the Circupool Core-55. I know it is probably more SWG than my 15000 gallon pool needs, but it was available and I figured less % generation would help the cell last longer. In this transition, I want to make sure I'm doing things in the proper order, so I'll share my plan here and ask for a sanity check to make sure I'm doing it right. I'm using Pool Math to get the proper amounts of chemical to add. Once I have the pool filled and pump running, I think my course of action will be:
1. Don't turn on the SWG yet...still have to get my water balanced and then add salt
2. Adjust CYI to 70 by adding 140oz of Stabilizer using the sock method. I'll split the large amount among 2 or 3 separate socks, one in the skimmer and 1 at each of my 2 returns. (takes a couple days to test at 70)
3. Adjust PH to 7.5
4. Adjust Free Chlorine to 3ppm using Liquid Chlorine.
5. Adjust Calcium to 450ppm using 52lbs of Calcium Chloride.
(question: the pool is gunite and plaster built around 1974. We had areas where plaster was coming loose, so the work done was to cut out all areas that were coming loose and patch. The patches are all in and then the entire pool was painted with Epoxy paint. Does this change anything regarding my need for appropriate calcium levels? Does the paint act as a barrier to prevent any leaching?)
6. Adjust borates to 50 by adding 573oz of boric acid.
7. Adjust salt level to 3500ppm by adding 439 lbs of salt.
8. Once water tests out, set the SWG %.
(question: I run my pump around 8 hours per day. Pool Math shows that the Core-55 can produce 2.3lbs of chlorine gas. At what % output should I initially set the Core-55 to run?)
thanks for any input...I appreciate the expertise of the folks here.
Patrick
3. Adjust PH to 7.5
Patrick
