Hi everyone, I'm new here and very new to pool automation. I'm installing a new Pentair Intellicenter. As you will tell with my questions, I have little to no experience with control panels and automation.
1. How to power the Purex Minimax 400 heater? Do I wire it to one of the relays or is direct power to the 20 amp 220V breaker?
2. Spoke with the Pentair, they suggested I splice one of the wires from the Minimax pressure switch and wire that to the 24 VAC on intellicenter. Is this the best way since there is not fireman switch on this unit?
3. Any advice with the installation of any other equipment and setup that I should be aware? I have a whisperflo pump circulating both the pool and the spa. Both are seperate bodies of water and need to be circulated seperately.
Thanks in advance!!!
