Winter readiness
clipperqb
2
nh
Hello,
I installed an above ground pool this year, took several weeks... worth it yes but a lot of work! anyway, I have not had time to do much landscaping and am wondering what I need to do for the winter. Attached is a typical picture of the surround. Do I need to put down some crushed stone around the pool for winter? Wondering about drainage and or water ice buildup on the outside of the wall?
Welcome to TFP! :wave: You probably do want to have something to cover and protect that area. Choices would vary based on the likelihood of flooding due to heavy run-off in that area. If that's the high side you might be fine. If prone to flooding, you want to keep water from rushing under the pool and causing a wash-out scenario. More posts to follow I'm sure. Great to have you with us.
Reactions: clipperqb
