The reason SWGs shut off below 60°F is that the chlorinator cell needs to work harder to produce chlorine in colder water. As the temperature of the water lowers, so does the conductivity of salt water. Most ions need a certain level of heat to separate and then rebind. The longer the saltwater chlorinator works harder than normal, the shorter the lifespan the cell has. So keeping your pool warm, especially during winter, is ideal for prolonging the life of your SWG.
