What are the Correct CYA Levels for an Outdoor Pool?
The
recommended levels of CYA depend on the way the pool is chlorinated.
A CYA level of 30-50 is
recommended when chlorinating with liquid chlorine. Pools in hot areas with intense sunlight can benefit from higher CYA levels to offset the degradation described below.
Salt Water chlorine Generation (SWG) pools seem to require a higher level of CYA, about 70-80 ppm, to operate efficiently. The theory is that the CYA is slow to "store" the chlorine as it is being generated so without enough CYA there is a build-up of chlorine that degrades the performance of the salt cell.[2]
An outdoor pool that is under a cage or cover does not need as much CYA as an outdoor pool in full sun.
