Maybe a dumb question...flow switch bad - no continuity when closed. So I twisted the wires on the phone plug and we're back. Why not just leave it that way?
Hi. It's a last ditch safety device. If the cell is on and the pump isn't moving water (like maybe the pump broke or something is badly blocked), the hydrogen gas that the cell makes can explode. Yes it can happen and has. Fix the flow switch.
Hi. It's a last ditch safety device. If the cell is on with the pump off (like maybe the pump broke), the hydrogen gas that the cell makes can explode. Yes it can happen and has. Fix the flow switch.
Anybody ever see pvc explode like this? Nothing blocked. All pop ups clear. Someone said an air pocket. It appears to have a bit of air bubbles in the sight cover of pump. Air bubbles do come out of some pop ups. Pump was on high speed. 30 psi at filter. It was after salt generator. Salt...
