- Jun 18, 2012
- 55
- Plaster
- Jandy Aquapure 1400
Hello,
I have a salt pool, plaster finish and from the time I have owned it I cannot keep the PH below 8. I tested twice this past weekend, once with chemicals which shows it over 8.2 (the max of the reading. I also have an electronic tester which showed 9.1, and I do believe that. I can add acid all day long and within a day or two it increases. I know that salt pools tend to increase PH, but this is more than seems normal.
I also had a jump in alkalinity recently, not sure why.
Can someone give me pointers on what I am doing wrong. Also would like input into salt testing. I have tried strips, the chemicals and also the unit self's reading and there are wild variations. What is in my logs is what I get using chemicals....the unit says I am around 2900 and the strips say 4000.
Here are my logs:
I am so so on entering additions. I try to log them....but I may miss some so take those with a grain of salt.
Here are my logs:
