This spring I'm going to be replacing my older Pentair single speed pump with a variable speed, adding a chlorine generator, and likely adding a gas heater. Right now, the pool is setup up to have the pump controlled by a on/off only switch. I'd like to add some automation controls, but I'm not sure what would be best in our situation since each manufacturer seems to have a wide range of options.
The pool is fairly simple, no spa and no lights (the removed the light when replacing the vinyl liner right before we moved in). It does have an automatic cover that's controlled by a keyed switch (but that probably shouldn't be automated for safety reasons).
